LT1/LT4 Tech 1993-1997
help buld my 94z
Old 12-08-2011, 05:40 PM
take the plug wires off that side and dry it very good. use electrical grease on the ends when reinstalling. im sureprized you not getting backfire at least.
  #142
Old 12-15-2011, 06:19 PM
sgtdupree's Avatar
i put in a 180 thermostat but my temp guage is gettin up to 240 degrees at times. should i be concerned? also im havin to add a lot of coolant but i dont see a leak. im addin about half a gallon about evey other day. also im get about 100 miles per tank. im definetly runnin rich. i can smell it. but only 100 miles per tank dont sound right
  #143
Old 12-15-2011, 10:02 PM
greenmachine96's Avatar
What does the oil look like? Not firing on 4 cylinders and losing coolant doesnt sound very good.
  #144
Old 12-15-2011, 10:54 PM
sgtdupree's Avatar
not firing on all cylinders was due to low gas. which seemed odd. it had enough gas to start but no for all cylinders to fire. soon as i added more gas it was all good. so now im jus worried about the coolant.
  #145
Old 12-16-2011, 01:26 AM
have you done a pressure test on your cooling system. it can help to find leaks.
  #146
Old 12-20-2011, 01:35 PM
sgtdupree's Avatar
i jus found this ticking to day. the car is runnin fine. any suggestions? do you think this is something i need to address asap?
camaro ticking - YouTube
  #147
Old 12-20-2011, 10:11 PM
have you reset the lifters? could be exhaust leak at the headers or lifter set wrong or failing.
  #148
Old 12-21-2011, 08:50 AM
sgtdupree's Avatar
i dont think its an exhaust leak. from where the noise is comin from it sounds like the lifters or rocker arms. idk. how do i reset the lifters? do u think i can keep driving it? it my daily driver.
  #149
Old 12-21-2011, 07:03 PM
shbox has a writeup on it. 4th Gen LT1 F-body Tech Articles
i think 69 has another link that may be better at explaining it.
  #150
Old 12-21-2011, 07:40 PM
torque_is_good's Avatar
sarge, I replied in your other thread
