LT1/LT4 Tech 1993-1997
help buld my 94z
Old 12-31-2011, 03:24 PM
sgtdupree's Avatar
do u guys recommend gettin a dyno or a tune from pcmforless or Solomon. I'm gettin about 80 miles per tank. I need something asap. if a dyno is good ima get it don't Monday when they readjust my rr.
  #152
Old 12-31-2011, 07:48 PM
i would look for a leak or a thief. not sure the motor can get that bad of mpg.
  #153
Old 01-01-2012, 10:29 AM
sgtdupree's Avatar
it's that bad. I have to fill up almost everyday. there no leak that I've noticed and I know theres no thief cuz I'll fill it up drive about 80-90 miles then fill it up again in on trip
  #154
Old 01-01-2012, 11:18 PM
greenmachine96's Avatar
Wow, do you have an SES light on? If it was using that much gas I would think you would get fuel trim codes.
  #155
Old 01-02-2012, 06:55 AM
sgtdupree's Avatar
nope no codes. I'm jus goin off the mpg I'm gettin and the overwhelming smell of unburnt fuel in the exhaust. I'm hopin a different tune will fix it.
  #156
Old 01-02-2012, 08:44 AM
have your injectors cleaned and tested. not very expensive.
  #157
Old 01-03-2012, 10:55 AM
sgtdupree's Avatar
it's at a performance shop now. they gonna go over it. do u recommend dyno tune or pcmforless?
  #158
Old 01-03-2012, 12:10 PM
if you can afford it and have access to a good dyno tuner then that is the best way. otherwise i would use solomon at LT1 PCM Tuning - OBDI/OBDII PCM Tuning/Programming Service
  #159
Old 01-07-2012, 01:20 PM
sgtdupree's Avatar
that ticking was a exhaust leak. that perceys gasket was shot.
  #160
Old 01-08-2012, 01:16 PM
sgtdupree's Avatar
think i blew another head gasket. this the second one in six month. this car is becoming a black hole
