LT1/LT4 Tech 1993-1997
help buld my 94z
Old 11-23-2011 | 07:26 AM
sgtdupree's Avatar
what rpm are you guys idling at? im at about 500 is that to low?
  #132
Old 11-23-2011 | 08:17 AM
im at 1k
  #133
Old 11-23-2011 | 09:10 AM
torque_is_good's Avatar
Originally Posted by craby
im at 1k
that's high unless you have a radical camshaft.
Stock camshaft for me and in Drive with brakes on it's around 600rpm's
parked in idle it's around 700 rpm
  #134
Old 11-23-2011 | 09:58 AM
no matter what i do it goes back to 1k sometimes up or down a little. do have a fair sized cam.
  #135
Old 11-23-2011 | 10:12 AM
Originally Posted by sgtdupree
is there a way to prove if a rear end has 373 gears? i found one for sale on craigslist for $300. is that a good deal or should i jus get my own installed? idk how expensive that is.
The surest way is to pull the rear cover and look for the ratio stamped on the pinion gear. If it is not stamped, then just count the teeth on the ring and pinion gears and do the math. Pulling the cover also lets you look inside and see what condition things are. Personally, I wouldn't buy any used parts without inspecting them.
  #136
Old 11-29-2011 | 05:46 PM
sgtdupree's Avatar
the maro ain't blown heat. today was the first cold day that I've drivin the car long enough to use the heater. but it only blew cold air. what should I check? thermostat?
  #137
Old 11-29-2011 | 09:10 PM
look at the sticky at the top of this section, says heater info, see if any of that helps.
  #138
Old 12-08-2011 | 11:34 AM
sgtdupree's Avatar
Default new issue
I jus changed my thermostat and I was pretty careful not to get the opti wet. but now it seems like maybe all 4 cylinders on the drivers side aren't firing. the header pipes r warm to the touch. I can hold the pipes after car was running for 10 minutes. but the passenger side pipes r hot like the should b. if any water got on the opti it was no more than a very tiny bit from when I was bleeding the lines. ima give it a minute to dry then Ina go check it. any other suggestions. it was workin fine this mornin.
  #139
Old 12-08-2011 | 12:43 PM
sgtdupree's Avatar
the driver side definitely ain't firing. there is no exhaust comin out the driver side pipe. I do have spark and fuel.
wtf this is pissin me off everyday it's something new.
  #140
Old 12-08-2011 | 01:27 PM
sgtdupree's Avatar
