LT1/LT4 Tech 1993-1997
help buld my 94z
Old 11-17-2011, 03:02 PM
torque_is_good's Avatar
it acts as if it's drive by wire. Your manual input and it's still running at higher rpm's
TPS????
  #122
Old 11-19-2011, 12:32 AM
sgtdupree's Avatar
fly by wire???? how do i check and or fic that?
here's a video of me playin around wit it
http://www.youtube.com/watch?v=k8hQw...e_gdata_player
  #123
Old 11-21-2011, 10:38 AM
sgtdupree's Avatar
I went to the exhaust shop to see about gettin my duals extended out the back. they said it can't b done and recommend I go back the original style single in dual out setup because I risk vapor lock wit the pipe runnin so close to the fuel lines. is that true? also I'm havin trouble starting the car. itll start and shut off when I put it n gear and start to give it gas afew time before it stays runnin. any suggestions? Ive change the ECM opti and fuel pump already.
  #124
Old 11-21-2011, 10:49 AM
sgtdupree's Avatar
i found this video of the exact same problem I'm havin with cold starts
  #125
Old 11-21-2011, 11:23 AM
could be injectors need cleaned and flow tested. whats the fuel pressure? have you checked the spark to make sure your getting a good strong blue spark.
  #126
Old 11-21-2011, 03:04 PM
sgtdupree's Avatar
  #127
Old 11-21-2011, 03:08 PM
sgtdupree's Avatar
the injectors r new ford 36lbs. and the plugs and wires r new also. Idk what the fuel pressure is but I put a new pump in also. I think the pump is a 250 I don't remember but I know it's bigger tha. stock
  #128
Old 11-21-2011, 03:33 PM
you get it tuned yet. if not i would be surprised if it ran at all.
  #129
Old 11-21-2011, 03:48 PM
sgtdupree's Avatar
yeah. I know a guy wit the program and data cable and he gave me the tune he had on his 94z
  #130
Old 11-21-2011, 06:35 PM
mine ran way rich with stock tune. did not idle well either.
