Right HID stuttering
Old Oct 18, 2011 | 04:33 PM
  #21
Grandpaswagon's Avatar
Again, you need to spend a little quality time checking the wiring. Both the +12 and grounds. The grounds can easily get a little corrosion on them and then cause all sorts of wierd symptoms.
If you suspect a bad ground, you can run a temporary wire from the ground connection for the light to the negative battery terminal. If your problem goes away, then you found the culprit. Just don't leave the temporary wire, find the bad ground and fix it properly.
Old Oct 25, 2011 | 02:18 PM
  #22
iLL95's Avatar
I Like to Party
Super Member
Ok I'd hate to bump this thread back up again but I checked my ground connections and they seemed snug. I took out the flickering hid, pluged my stock light in and it lit up perfectly. Im so confused as to what is going on here. Should I get a relay? Should I up the fuse going to the headlights? My stock light never flickered so I know it cant possibly be a ground connection, its a problem of voltage im guessing?
Old Oct 25, 2011 | 02:23 PM
  #23
iLL95's Avatar
I Like to Party
Super Member
I failed to mention it's Xentec HID, I here their products are horrible. Should I just get like a DDM kit or something? What confuses me is a switched EVERYTHING around and the left HID always works fine and the right doesnt
Old Oct 25, 2011 | 03:45 PM
  #24
1994 Z28's Avatar
Sounds like your not getting enough power to the right side. You might want to try hooking them straight up to the battery or even putting a jumper wire from the battery to the right HID.
DrQuincy
Oct 10, 2011 06:53 PM
gagemonster
Jul 1, 2011 06:52 PM
3800camaro
Jan 31, 2011 05:44 PM
jjhenderson17
Dec 3, 2010 02:52 PM
87camaro
Apr 5, 2006 05:26 PM
