Right HID stuttering
Old Oct 12, 2011 | 11:18 PM
iLL95's Avatar
I Like to Party
Super Member
Originally Posted by 3800camaro
Have you tried switching the balusters around to see if that's the problem?
I switched the ballasts and the bulbs and only the right side stutters
Old Oct 12, 2011 | 11:40 PM
3800camaro's Avatar
Have you checked the voltage at the balusters? How's the wiring connection on the right side?
Old Oct 13, 2011 | 11:13 AM
iLL95's Avatar
I Like to Party
Super Member
Im going to check that today. i dont know why no matter what I do the right ballast is always searing hot. Might actually be the wiring. What should I check for?
Old Oct 13, 2011 | 12:11 PM
iLL95's Avatar
I Like to Party
Super Member
I also noticed my high beams come on but barely when I turn my lows on, you can see from the picture
Old Oct 13, 2011 | 04:04 PM
Grandpaswagon's Avatar
I would double check all of the wiring, very carefully. Also, make certain that your grounds are good and clean. Any rust or crud on the grounds can cause wierd electrical problems.
Old Oct 13, 2011 | 05:04 PM
Spatfieya's Avatar
This. You can do a voltage drop on the ground wire from the light to the chassis. See if there any lost voltage causing those lights to mess up.
Old Oct 13, 2011 | 08:36 PM
iLL95's Avatar
I Like to Party
Super Member
I took + and - cables off the battery and put them back on and they work fine..weird
Old Oct 14, 2011 | 05:56 AM
Sounds like it was a poor connection and just redoing them got them cleaned up and tight.
Old Oct 14, 2011 | 10:14 AM
iLL95's Avatar
I Like to Party
Super Member
Yeah thanks for the help, i'll bump this thread if I need anymore help
Old Oct 18, 2011 | 11:19 AM
  #20
iLL95's Avatar
I Like to Party
Super Member
*Bump* I think I may have a bad ground/corrosion on the right side. My right HID started blinking again. I recieved my fog light HID's and installed them (PITA) a bit ago( fogs never worked before then), I went to turn them on and the left fog worked but the right was blinking. WTF
