Another z28 wont start issue.
Old 07-17-2012, 07:42 PM
Greg08's Avatar
ok, camaro is completely fixed. had the wiring redone near the plugs behind back left seat
  #52
Old 07-17-2012, 09:03 PM
man you were so close to getting it yourself. cool you got wheels without issues. lol, except fuel level.
  #53
Old 07-19-2012, 10:21 AM
Greg08's Avatar
i know right! but wait crabby there's more! lol
The camaro died while driving, due to injectors not firing, but the fuel pump is priming everytime now and all that so that is fixed
  #54
Old 07-19-2012, 05:44 PM
Greg08's Avatar
I'm going to check on all the wires icm-pcm, a ton of useful info on this issue
  #55
Old 08-29-2012, 09:25 PM
Greg08's Avatar
I come to this thread with great news..
I swapped the opti and on the first try didnt line it up properly. It's very easy to miss align the one that is correct to the dowel pin on the cam. I lined it up right and it fired up.
when it wasnt lined up i was getting no start.. I checked if i was getting spark at the coil and it was ticking like it should. but when i cranked it it just wouldnt run, and after the key was out of the start position it would kick a couple times before it shut off.
  #56
Old 08-31-2012, 11:12 AM
Greg08's Avatar
Ok, it runs nice, but at low rpm it rumbles a bit, brought it to a good mechanic to see if he could help me see if it wasnt on all cylinders, and he thinks it isnt either.. Idk how to check which one isnt. but there is no code, so i suspect its a plug wire not all the way on or something.
  #57
Old 08-31-2012, 11:37 AM
what plugs are you using? did you drop one when installing? hate to say this but probly better have a look at the plugs. the one not firing will be nice and clean.
  #58
Old 08-31-2012, 09:00 PM
Greg08's Avatar
denso copper.. good price and i plan on swapping over to iridium in a little when i change my exhaust mani gaskets
thamekanik502
08-11-2011 10:27 AM
mjstempky
02-19-2011 01:17 PM
ridinsolo2
05-18-2008 12:18 AM
hmodel88
82-92 V8 Tech
05-04-2008 01:31 PM
89Rally
05-03-2007 01:49 AM
Quick Reply: Another z28 wont start issue.
