gas tank removal
Old Nov 12, 2008 | 07:14 PM
blue max's Avatar
Default RE: gas tank removal
thanks guys, i cut the tailpipe that had the dual mufflers attached to it. the tank came out easy .
i have a new problem.
Old Nov 12, 2008 | 11:00 PM
ORIGINAL: blue max
Are you gonna keep it to yourself, or share it with the rest of the class?
Old Nov 18, 2008 | 12:36 PM
blue max's Avatar
my new problem is that fuel will not go thru the injectors of the tpi system. i cleaned the fuel tank, installed a new fuel pump, in tank, replaced fuel pump relay, and still no fuel to the injectors. if i spray injector cleaner into the throttle body, it starts for a second, then nothing. do you have any other suggestions that could cause this problem. thanks
Old Nov 18, 2008 | 03:01 PM
MadMikeZ28's Avatar
Got spark? Check your ignition module regaurdless. Thats where the injectors will get a signal to fire. Also have you checked for an injector pulse? One wire will be power and the other will be a pulse/ ground signal.
Old Nov 19, 2008 | 11:04 PM
blue max's Avatar
the ignition has spark, the injectors do not squirt. how do you test the injectors wiring, or for the pulse. if you change the ignition switch, does the original key code affect the new set of keys when you cut the new key with the chip. a dealer told me the key code must match the ecu or the engine won't start. it thinks someone is trying to steal the car. it this true.
Old Nov 20, 2008 | 05:09 PM
MadMikeZ28's Avatar
I finally had to replce my passkey lock cylinder. What mine did was it would not crank the engine. Is your security light on? The VATS will cut off the fuel pump while cranking and starter.
To check for injector pulse, unplug and injector and with the key on probe the plug for power. Find which one is the power then hook your test light to the + of the battery and while some one is cranking probe the other wire and watch for the light to pulse. A noid light works best but a test light is fine in a pinch.
Old Nov 20, 2008 | 10:03 PM
blue max's Avatar
my car cranks the engine and it has spark. i wasn't aware of the vats system or passkey cylinder. does the ecu control both. maybe the ecu is bad.
Old Nov 21, 2008 | 12:37 AM
MadMikeZ28's Avatar
The passkey and vats are in the same system. If its cranking then it most likely is working. Have you checked for fuel pressure while cranking? You know you have spark so check for pressure while cranking and pulse to the injectors then you can pretty much elimate a fuel system problem.
Old Nov 21, 2008 | 09:09 PM
blue max's Avatar
o.k. i bet the fuel pressure regulator is weak or bad. i believe it is located on the rear of the fuel rail and you only replace the diaphram. i will check the fuel pressure. thanks.
jwarren219
Feb 3, 2020 12:15 PM
kats69
Jul 2, 2009 11:34 PM
patrickd
82-92 V8 Tech
Jan 26, 2009 05:50 PM
6v49der
Dec 18, 2007 09:08 PM
90rs
Dec 24, 2005 12:15 PM
