LT1/LT4 Tech 1993-1997
Scan tool
Old Oct 20, 2009 | 06:20 PM
jamesfs912's Avatar
Default Scan tool
I'm starting to realize I probably need to invest in a scan tool. I have a 1994 so I know it needs a special connector. I found one online, is this what I need to scan and view computer functions and does it come with everything I need? Also what do you guys use? Thanks
http://www.etooldirect.com/autoxray-...2&cvsfp=AX6000
Old Oct 22, 2009 | 11:30 AM
jamesfs912's Avatar
ttt.....
Old Oct 22, 2009 | 11:45 AM
CNCman's Avatar
Yes , the AutoXray will do fine. I bought a 5000 model new on Ebay for 150.00. But i just checked and the 6000 model for 270.00 at Tool Direct may be a good price right now. Ebay has some for a little more but a few wks ago they were cheaper ?
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Oh ! mine works very well and you can scann most vehicles from 1984 and up as well. Also ! If you get a used one, make sure it has all the cables ! AND it is in ENGLISH too, some are in Spanish only and you cannot switch to english !!
Old Oct 22, 2009 | 12:30 PM
Skyline's Avatar
CNCman,
Do you know if that Autoxray will work on the 95 Z28 that has an OBDII plug, but runs a OBDI protocol?
Old Oct 22, 2009 | 12:42 PM
rwing7486's Avatar
This is what I use. Its cheap and works great......thats if you have a laptop.
http://www.aldlcable.com/
Old Oct 22, 2009 | 02:03 PM
CNCman's Avatar
I think so, but not sure, so I emailed AutoXray and am waiting for a reply from them to be certian, sorry for the wait, it may be tomorrow before they reply like last time. My 94Z has OBDI connector which works good. There is probably someone here who knows for sure, like " Libertyforall1776 " in this post https://camaroforums.com/forum/showt...light=Autoxray
Here is a discussion simular to your question
I will post AutoXray's reply when I get it.
Also the next thing I want to get is the cable and software that " rwing7486 " mentioned above LOOKS NICE !!
Old Oct 22, 2009 | 05:55 PM
Skyline's Avatar
What software are you using with that cable?
Old Oct 22, 2009 | 06:43 PM
rwing7486's Avatar
I use FreeScan. Very easy to use
Old Oct 22, 2009 | 07:33 PM
srode's Avatar
I have a tech 2 which works great on my truck - doesn't help with my camaros though...
Old Oct 23, 2009 | 06:22 AM
CNCman's Avatar
Default AutoXray will scan OBDI PCM with OBDII connector
AutoXray replied and said it will scan your 95Z with the OBDI PCM that has an OBDII connector. Here is the proof ...
http://www.tradervar.com/GM-OBD-II-M...ray-P35301.htm
When you buy the AutoXray, it will have several different cables for different pre-1996 OBDI systems and 2 OBDII cables for 1996 to present year vehicles. The cable above comes with the kit, so you do not need to buy it seperatly. I like it because I can scan just about everything from 1984 and newer cars and trucks.
Here is another link about FreeScan and TunerCat you might want to check out too !!
http://www.f-body.com/forum/showthread.php?t=16384
If you buy an AutoXray used, make sure it comes with all the cables and is an English version. Hope this helps.
jtrotter
May 3, 2012 10:37 PM
89 Red Devil
Jul 22, 2010 05:20 PM
draggo144
82-92 V8 Tech
Mar 27, 2009 04:33 PM
Brians 88 IROC
82-92 V8 Tech
Aug 31, 2008 08:58 AM
twistedpyro
Mar 15, 2008 12:34 AM
