scan tool won't communicate 96
Old May 3, 2012 | 07:04 PM
jtrotter's Avatar
Default scan tool won't communicate 96
OBD II scan tool won't power up when I hook up to my car. When I hook it up, it turns on fuel pump. Service engine light has been on for a while, car haa been running good, till recently won't crank as well like it is flooding. Has a dead spot on bottom end and has intermitant miss sometimes. have put new fuel pump 7 months ago because wouldn't run. Basically I want to know if anyone has had prob getting scan tool to work. Hooked up to 96 V6 (mine is 96 LT1 SS) and worked.
Old May 3, 2012 | 07:19 PM
Check your fuses. Your ALDL port gets it's power being on the same circuit as the cig. lighter/power socket.
Old May 3, 2012 | 08:25 PM
jtrotter's Avatar
Thanks you hit it right on. Was the fuse and code reader works I have 7 codes
Old May 3, 2012 | 09:50 PM
BasicConcepts's Avatar
Technical User
wow 7 what codes
Old May 3, 2012 | 09:58 PM
jtrotter's Avatar
tps sensor low input coolant resevoir sensor(I already knew this) o2 sensor circuit 1 bank 1 sensor 2 o2 sensor low voltage bank 2 sensor 2 o2 sensor heater circuit bank 2 sensor 2 secondary air injection system torque convertor brake switch b circuit low I assume these are just bad o2 sensors all way around and torque convertor brake switch b not sure what this means. maybe solenoid in trans not sure, what scan tool said
Old May 3, 2012 | 10:04 PM
Technical User
thats probably a faulty brake light switch under the dash, when you hit the brakes that tells the computer to tell the trans to disengage the torque converter
Old May 3, 2012 | 10:37 PM
jtrotter's Avatar
thanks alot guys this is all new to me . mostly been in the 60 70 model scene awhile. trying to put up some of the cars ive owned and redone .kick A site by the way . all though car has just shown issues , and could tell wasn`t running the same still hauls ***!. just got a code reader today , realy lost without it on these cars . again thanks
89 Red Devil
Jul 22, 2010 05:20 PM
jamesfs912
Oct 23, 2009 06:22 AM
draggo144
82-92 V8 Tech
Mar 27, 2009 04:33 PM
Brians 88 IROC
82-92 V8 Tech
Aug 31, 2008 08:58 AM
twistedpyro
Mar 15, 2008 12:34 AM
