scan tool won't communicate 96
OBD II scan tool won't power up when I hook up to my car. When I hook it up, it turns on fuel pump. Service engine light has been on for a while, car haa been running good, till recently won't crank as well like it is flooding. Has a dead spot on bottom end and has intermitant miss sometimes. have put new fuel pump 7 months ago because wouldn't run. Basically I want to know if anyone has had prob getting scan tool to work. Hooked up to 96 V6 (mine is 96 LT1 SS) and worked.
Check your fuses. Your ALDL port gets it's power being on the same circuit as the cig. lighter/power socket.
Thanks you hit it right on. Was the fuse and code reader works I have 7 codes
wow 7 what codes
tps sensor low input coolant resevoir sensor(I already knew this) o2 sensor circuit 1 bank 1 sensor 2 o2 sensor low voltage bank 2 sensor 2 o2 sensor heater circuit bank 2 sensor 2 secondary air injection system torque convertor brake switch b circuit low I assume these are just bad o2 sensors all way around and torque convertor brake switch b not sure what this means. maybe solenoid in trans not sure, what scan tool said
Originally Posted by jtrotter
(Post 622709)
thanks alot guys this is all new to me . mostly been in the 60 70 model scene awhile. trying to put up some of the cars ive owned and redone .kick A site by the way . all though car has just shown issues , and could tell wasn`t running the same still hauls ***!. just got a code reader today , realy lost without it on these cars . again thanks
