LT1/LT4 Tech 1993-1997
Rocker noise?
Old Aug 6, 2010 | 07:23 AM
  #21
critt86's Avatar
my gaskets are coming in today. I found where the gasket was blown out its right above the center two pistons on the passenger side. im just not excited about trying to get that header looses and sliping the gasket in. Another problem is that my exhaust is completely welded together... lol this is not gonna be fun....
Old Aug 18, 2010 | 11:17 PM
  #22
kidashley25's Avatar
Intermittent lifter noise is almost always the result of oil pressure problems. Make sure the oil pressure isn't dropping and that you have sufficient oil to for the oil pump to pick up and pump through the oil journals. Another possibility is that you may be "foaming" when the engine RPM goes too high. If you're pumping foamed oil, the lifters won't function properly. Foaming is partially caused by high RPM, but if the oil viscosity is too light, that too can contribute. If you're running a 5 W 15 oil, you might want to consider a slightly higher viscosity, but don't go too high. to prevent rocker noise.
__________________________________________________ ________________
Bocar Parts Rocker Arm Oil Baffle
  • 1993|1994|1996::GTI; 4Cyl 2.0L;
  • 1993|1996::GL; 4Cyl 2.0L;
  • 1994|1995|1997|1998::GL; All Engines;
  • 1995|1997|1998::GTI; All Engines;
  • 1997|1998::K2; 4Cyl 2.0L GAS, Naturally Aspirated, ABA;
  • 1999::GL; 4Cyl 2.0L ABA;
  • 1999::GLS; 4Cyl 2.0L ABA;
  • 1999::GTI; 4Cyl 2.0L ABA;
  • 1999::Wolfsburg Edition; 4Cyl 2.0L ABA;
B_Dubya
Mar 27, 2015 02:10 PM
Showoff67
Nov 11, 2011 01:35 PM
dogdog130
Mar 13, 2011 12:34 PM
mattzilla_22
Aug 7, 2010 01:00 AM
thebandit110
May 4, 2007 08:01 PM
