LT1/LT4 Tech 1993-1997
Rocker Arm, Rods, Lifters. Insane Noise
Old Nov 8, 2011 | 12:13 PM
Showoff67's Avatar
Default Rocker Arm, Rods, Lifters. Insane Noise
i can not figure this out for the life of me. been searching the web for two days. I just replaced all front seals. Car was recently rebuilt the top end. all stock parts put back into it. New Parts of Course. The Car has a weird noise comming from the passanger head from one of the rocker arms/rods and i think it is a stuck lifter but i am not sure.. any ideas heres a video of what it sounds like. any help guys. i cant figure this out i went back and relashed the rocker arms and that didnt help just bought some seafoam but im so tired been up past two days work on it. 1st thought it was alternator, then tensioner but after take valve cover off i discovered this. no marks or anything rocker arms where all tight and nice. i just dont know
SDC10657.mp4 video by CamaroGoes - Photobucket
Old Nov 8, 2011 | 02:01 PM
torque_is_good's Avatar
how did you adjust the rockers? Did you do it with the engine idling, back off until clicking sound, tighten until the sound goes away and then another 1/3 to 1/2 turn more?
Have you checked for a broken valve spring?
Old Nov 9, 2011 | 05:53 PM
Showoff67's Avatar
i dont get the sound at idle. only when revving motor it makes the sound. i gonna tear off opti again and everything i just did to it and see if i did anything wrong. would a stuck lifter be making the noise at idle? its a weird sound none the less just cant seem to figure it out. all i did was take off old timing oil seals, waterpump, opti and hub and replaced them and put everything back together but then when starting it made the noise. i adjusted the rocker arms at idle and then again when motor was off cause there are many ways to adjust them.
Old Nov 10, 2011 | 05:08 PM
it's not the opti
go back and check your rocker adjustment. Doing at idle is how I do it
if you still have the noise, you really need to check for a broken spring
Old Nov 10, 2011 | 07:58 PM
that sounds like a air noise of some sort. your sure the noise is coming from under the valve cover?
Old Nov 11, 2011 | 01:35 PM
Showoff67's Avatar
im sure its coming from the cover. i already adjusted like 2 times still making noise how do i check for a broken spring all of them look in great shape.
critt86
Aug 18, 2010 11:17 PM
mattzilla_22
Aug 7, 2010 01:00 AM
libertyforall1776
Oct 8, 2007 12:05 PM
CamaroKid81
Jun 28, 2007 03:01 PM
FireCamaro02
LS Series Tech
Jan 4, 2007 01:12 PM
