LT1/LT4 Tech 1993-1997
Help: MAF Sensor Issue?
Old Oct 15, 2009 | 10:58 PM
383Stro's Avatar
Yes, next to the throttle body, Try this to check the fuel system: turn the key to the on and listen to see if the fuel pump turns on and goes off again. Then check the fuel pressure in the rail there is a black cap that screws off and then you have a valve, fuel should come out when depressed. If there is pressure there, cycle the pump again and let the vehicle sit for a while then check it again. I doubt it is the fuel system though.
Old Oct 15, 2009 | 11:09 PM
SixShooterCamaro's Avatar
Do you think when the car jerked real bad going from 1st to 2nd it could have shifted somethings? im asking cuz maybe it may be a leak from my intake manifold or the heads
Old Oct 15, 2009 | 11:31 PM
If this helps: I have filled my tank 5 times and gotten 430 miles... now call me crazy but i dont think the IAC has the ability to do that to my car lol
Old Oct 16, 2009 | 01:23 AM
95slvrZ28's Avatar
Have you checked for vacuum leaks yet?
Old Oct 16, 2009 | 02:41 AM
yeah I did a visual check... I did the carb cleaner trick and also had a shop look it over and no vac leaks
fuhhuayt
May 5, 2011 01:04 PM
ThundercatZ28
Mar 17, 2011 07:48 PM
EagleRex
Jul 20, 2010 03:36 PM
350rs
Jul 10, 2007 08:29 PM
