Oxygen Sensor Issue..Gas Guzzler
Old Mar 16, 2011 | 10:24 PM
ThundercatZ28's Avatar
Default Oxygen Sensor Issue..Gas Guzzler
Hey I had my car tested and it said it has an upflow O2 sensors were bad. Only bought one like a dummy forgetting I have two. I replaced the stock sensors with a Denso Sensor. Cleared the computer but now its drinking more gas. I will replace the other sensor but is that the problem or are Densos bad and I need to go stock?
Old Mar 16, 2011 | 11:03 PM
libertyforall1776's Avatar
Denso's are quality, see:
http://www.camarohomepage.com/project/part3.htm
Check your MAF wires to ensure they are clean... Ensure the O2 wiring & plugs are good as well.
Old Mar 17, 2011 | 01:50 PM
auto's Avatar
could also be injectors.. gunna send mine in to flowtest n clean.
Old Mar 17, 2011 | 07:48 PM
Thanks fellas. I'm going to check those wires and injectors while installing another sensor. My fuel meter is on the fritz too and I dont want to send it in. Cost a butt load.
djsquare1
Sep 16, 2012 11:08 AM
numskull223
Oct 19, 2011 10:03 AM
amwatchinya
Jun 24, 2011 02:29 PM
78LT350
May 2, 2010 09:04 AM
3.4CamaroCDOG
May 3, 2008 12:17 PM
