LT1/LT4 Tech 1993-1997
Does Bypassing Fix Your VATS Problem?
Old Jan 13, 2012 | 04:19 PM
chad kennith's Avatar
Default Does Bypassing Fix Your VATS Problem?
Hi, my cars security light has been on for about 2 years, but until recently hasn't caused any problems with starting. When I get in the car it doesn't turn over or anything.Then I'll wait for 5 minutes and it will start. My question is, will soldering in a resistor and bypassing it fix my problem, or will I need to get it tuned out of my PCM? Thanks.
Old Jan 13, 2012 | 04:27 PM
BasicConcepts's Avatar
Technical User
ya just get an ohm meter and check the chip in the key then just solder the same ohm resistor into the 2 wires in the orange casing under the dash
Old Jan 13, 2012 | 04:31 PM
Does anyone know what value of resistor I will need for a 1993 z28?
Old Jan 13, 2012 | 04:35 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
there are different values. you'd have to either find out from the dealership with your VIN or measure it yourself. I think they used 3 different values
Old Jan 14, 2012 | 11:09 AM
there are 15 different ones, check number 26 on the list here, also 25 and 27
4th Gen LT1 F-Body Tech Aids
Old Jan 22, 2012 | 07:25 AM
mezzyshredder's Avatar
Banned
I have a similar issue. Sometimes when I go to turn the key to start the car, the car will do nothing and the security light will stay on for exactly 2 minutes once the key is removed. After the 2 min., the security light goes out and the car starts up. I know this is supposed to be some kind security thing, but eh does it do it in my driveway when simply trying to start it? Is the problem in the car with the register? Or could it be my key? Or even maybe the lock assembly in the column? Any help with this frustrating problem would be greatly appreciated. Thanks!
9434V6
May 24, 2019 10:18 AM
Mr. Irocz28
Apr 25, 2012 07:30 PM
Leeet
Sep 8, 2009 04:16 PM
tripwire1124
Aug 19, 2009 02:17 PM
mineornone
Jan 9, 2008 02:39 PM
