Bypassing or Eliminating the VATS???
Old Nov 5, 2007 | 07:53 AM
mineornone's Avatar
Default Bypassing or Eliminating the VATS???
I was wondering if the VATS system could be bypassed or eliminated all together?I cant finda wiring diagram online to see andI would like to do a push button start on my car, is it possible to have the ECM reprogramed to eliminate the VATS and take it out?
Old Nov 5, 2007 | 03:19 PM
Default RE: Bypassing or Eliminating the VATS???
This seems to be a common problem lately. I've posted this answer before recently, so here goes again. The chip in the ignition key is a resistor and the circuit in the ignition switch needs to be bypassed with an inline resistor to match the resistance of your key. This website will explain the system and gives bypass instructions.
www.passlock2.com
Old Nov 5, 2007 | 06:39 PM
Check the sticky in the LT1 section.
Old Nov 6, 2007 | 07:13 AM
mineornone's Avatar
Yeah i seen the post with resistances thanks for the info!! how do i know which key i have?
Old Nov 6, 2007 | 12:37 PM
ORIGINAL: mineornone
Depends on why you're asking. If you need to know for bypassing, you need to read it with a meter as shown in the directions. If you need a duplicate key made, the key maker should have a reader that the key gets slid into to let them know which resistance key blank to use. There are only ten different variables.
Old Jan 9, 2008 | 02:39 PM
kaoss_11's Avatar
Should I just go to the dealer to get another key made?
9434V6
May 24, 2019 10:18 AM
Mr. Irocz28
Apr 25, 2012 07:30 PM
chad kennith
Jan 22, 2012 07:25 AM
HYDRA_SH0CK
Aug 13, 2010 08:50 AM
dustinb
Aug 7, 2008 09:04 PM
