Ok, problem with the VATS. Anybody know?
Old Aug 4, 2009 | 11:05 PM
tripwire1124's Avatar
Default Ok, problem with the VATS. Anybody know?
A little while ago i posted on this forums about how i was doing an engine swap. I was swapping a 3.4 to a 3.8 and from automatic to a 5 speed. so far we have got the engine in and hooked up (along with the 5 speed) and all the electronics and we can get the car to turn over (and even get spark) but it just wont fire. We found a primer line to the fuel pump and hooked that up to the battery and then tried starting it and it still wouldnt fire. the security light comes on, but it still cranks over. Im thinking the problem is something that has to do with the BCM. Its really starting to get me frustrated. Any input would be nice.
Old Aug 11, 2009 | 11:25 PM
Anybody have an idea? I was also told it may not be the VATS. maybe a sensor. one proble it may have is the firing order going to affect this? I think the 3.4 and the 3.8s had different firing orders. Gorn i know you probably know something, cause you saw this coming.
Old Aug 11, 2009 | 11:57 PM
yah gorn whats up? lol.
Old Aug 12, 2009 | 08:24 AM
Did you change the PCM? 3.8 & 3.4 have different sensors & PCM. The 94 car does not use a BCM. The firing order is different: 3.4=1-2-3-4-5-6, 3.8=1-6-5-4-3-2.
Old Aug 12, 2009 | 10:34 AM
Since you used the Harness and the PCM from the 96 I would think the firing order would not be the issue. I know the VATs system needs something. If it even sees the new PCM it would know its not the same Vin. The thing I have no clue about is how the 96 PCM is reacting to all the none 96 systems it is seeing or its looking for systems that are not there. All it would take on one wire on one connector to be pinned differently and everything would shut down or worse fry the system. There may be someone out there with the know how to do this. It aint me. I just know enough to know that the chances it would be plug and play where pretty slim.
Old Aug 13, 2009 | 10:23 AM
heres a link to a video that may help you guys get a visual.
http://www.youtube.com/watch?v=yGLpSM6YirM
Old Aug 14, 2009 | 08:14 AM
The VATS prevents cranking and shuts down the fuel injection. It does not shur down the spark. The system consists of the special key with resistor pallets, a VATS module under the dash which reads the resistance of the resistor pellet, and if it is correct it will signal the PCM that all is OK. If all is OK then the PCM activates the stater relay which then energizes the starter solenoid, at the same time it will allow the injectors to fire.
Since the engine cranks the VATS is "probably" OK. You may want to verify this with some NOID lights and see if the injectors are being pulsed.
I seem to remember (although not positive) that a VATS module will only mate up to the PCM only once, so if it is mated to the original PCM you may have to replace it wit a new one, need to do some more research on this.
Old Aug 19, 2009 | 02:16 PM
Masospaghetti's Avatar
Well, if its cranking it has compression...you have spark, and you've added fuel, so it SHOULD run.
Im not sure of the best way to verify the firing order is correct but I doubt its the BCM. When I have a VATS issue the car will not crank.
Old Aug 19, 2009 | 02:17 PM
You sure your fuel injectors aren't plugged? I would unbolt your fuel rail and crank it over just for a moment to make sure you're getting fuel out of them (there's probably an easier way to verify this but I don't know it).
chad kennith
Jan 22, 2012 07:25 AM
mccoyj91
Nov 3, 2010 06:13 PM
fasfzr1
Jun 14, 2010 07:07 PM
Leeet
Sep 8, 2009 04:16 PM
