LT1/LT4 Tech 1993-1997
after 30 min (camaro z28 1994)
Old Sep 25, 2006 | 03:21 AM
xavierz28's Avatar
Default after 30 min (camaro z28 1994)
[:@] my car runs bad, it jerks and stutters[X(]
I changed the injectors, catalyctic convertor, spark plugs, cables, and removed the super chip. It worked about 50% better than before. I changed the STC and that didn't help. I removed the super chip and the fans stopped working. When I put the chip back the fans work directly but it still runs bad. So I went ahead and removed the chip and did a connection so they'd work directly (without the chip). Now the car doesn't heat up, but I feel like it still needs strength. After about 30 minutes it starts jerking and stutters, but then releases. Someone please help me so I can get this fixed!
Old Sep 25, 2006 | 04:11 AM
VCP Z28's Avatar
Default RE: after 30 min (camaro z28 1994)
your running out of gas.
ha, i also have a 94 Z28 but this is a good one. I'm not sure right now but i'll get back to you. Maybe someone else on here might know.
Old Sep 25, 2006 | 04:15 AM
VCP Z28's Avatar
HERE
lots of good ideas in there
Old Sep 25, 2006 | 01:24 PM
Is the serivice lite lit? If it is lit fix that problem first. If not, you will have to do some trouble shooting. Let the car warm up till it runs bad & then check the fuel pressure and pressure regulator, you will need a FI pressure gauge (se sticky for procedure). Get a scanner, not a plain code reader, and read the inpt from the ETC, TPS, IAT, & O2 sensors. Verify that the readings make sense, ex. you don't want the ETC telling the computer that the water temp is 100 deg when you know it is 200 deg. If the sensors look OK, check uot the ignition, make sure all connections between computer, optispark, coil, & ignition module are tight & clean. If still bad, start replacing or swapping the igntion components, go with least costly item first.
Old Sep 25, 2006 | 06:43 PM
sellc's Avatar
Check your breather tube from the valve cover to the throttle body. I see a lot of times raw oil gets sucked into the throttle body and it really causes a lot of problems like what you are talking about. Oil leaks are a MAJOR factor in a lot of problems with the LT1 power/drivabilty problems in older vehicles. Also make sure to remember if the firing order and plug gaps were proper when installed.
Then there is always the coolant temp sensor that could be out of whack, but I am thinking oil saturation in possible multiple known areas.
Let us know what you find.
Old Sep 27, 2006 | 12:57 AM
xavierz28's Avatar
Thanks. I checked the throttle body and it was filled with oil. The gasket wasn't good either. I'll be changing that tomorrow. I'll check everything you all advised and I'll get back with you all. Thanks...
David Kent
Nov 10, 2011 06:20 PM
wazowski
Sep 3, 2011 12:06 AM
quinton1810
Nov 24, 2010 08:25 AM
sebi1990
Jul 13, 2010 04:35 PM
sabercatman22
Jul 5, 2010 07:46 PM
