1994 Camaro Z28
Old Sep 2, 2011 | 03:30 PM
wazowski's Avatar
Default 1994 Camaro Z28
I have a 1994 Camaro z28, its complete factory.
350 5.7L Lt1 6spd.
It has been blowing blue smoke out the exhaust when i get on it, and i loose about a qt of oil every week.
Im guess its the piston rings? Now my question is i want to beef up the engine some and give me some bigger horses.!! I have a buddy that will do the any kind of work for me for a couple hundred in labor.
Anyone have any idea what i can add or chnge on the enging to beef it up? for around $2,000 including the cost of parts to replace the piston rings?
thanks.
Old Sep 2, 2011 | 05:15 PM
yep most likely the rings. you may get away with a economy rebuild with 2 k but thats about it
Old Sep 2, 2011 | 05:22 PM
From what you are telling us it would appear that this engine needs more than piston rings. Things like cylinder reboring, new oversize pistons & rings, reground crank, new bearings, etc.. So, why not go for a 383 stroker, the parts price to build a 383 should not be much more than the price of rebuilding the 350.
Old Sep 2, 2011 | 08:05 PM
wazowski's Avatar
i would but i dont know anything about how to build an engine lol.. all i know how to do is drive and do minor work but a 383 stroker. I have thought about that.
My engine in the camaro still runs strong, it was just setting a year before i bought it. and only has 54k miles on it. So, thats probably have my guy do that, if he is able to change it in to a 383.
thanks
Old Sep 2, 2011 | 08:41 PM
RFxCamaro's Avatar
Perform a leak down test. It could be just burning oil from a leaky valve. If so you can just replace the valve guides which is like a $50 job.
Old Sep 2, 2011 | 09:08 PM
if i remember this right,,, smoke on acceleration is rings, deceleration is valves. but yah better do the heads while there off.
Old Sep 2, 2011 | 10:18 PM
Valve seals for 50 bucks. You change the guilds and its a complete valve job. Depending on the machine shop it could cost $800.
Seems unlikly the rings need replaced at 54K miles. Valve seals are not a tuff job to do and they are cheap. You only need to remove te valve cover. Tuffest part of the job is getting the valves ajusted. Check Youtube for a video guide.
Old Sep 2, 2011 | 10:54 PM
RFxCamaro's Avatar
My bad I meant seals. You should do a leak down to check the rings anyways. You would also need to check compression before replacing valve seals or its a head job if the valve falls.
Old Sep 3, 2011 | 12:06 AM
wazowski's Avatar
cool tyvm everyone!
David Kent
Nov 10, 2011 06:20 PM
andersonj
Mar 6, 2011 07:32 PM
quinton1810
Nov 24, 2010 08:25 AM
sebi1990
Jul 13, 2010 04:35 PM
sabercatman22
Jul 5, 2010 07:46 PM
