Valve Adjustment on LT1
Old Sep 2, 2011 | 08:56 PM
pcarollo's Avatar
Question Valve Adjustment on LT1
I replaced the LT1 engine in my 1994 Z28 back in March, currently have about 10,000 miles on it. Runs great! Recently I have heard it 'ticking', normally after it has warmed up. Still runs just fine, just ticks. Someone suggested that it needs the valves adjusted, does that sound right? And what all is involved with it?
Old Sep 2, 2011 | 09:05 PM
greenmachine96's Avatar
could be try to see if it sounds like it is coming from the top end. To adjust the valves follow these How to adjust valves on a chevy small block engine These explain it pretty well. Just check in a service manual or someone one here who knows how many turns after zero lash, I believe it is the standard 3/4 turn like the rest of sbc's but not sure.
Old Sep 2, 2011 | 09:13 PM
whats the oil pressure when its warmed up and idling?
Old Sep 2, 2011 | 09:18 PM
pcarollo's Avatar
Soemtimes one section below 80, other times right in the middle. Is that good?
Old Sep 2, 2011 | 09:22 PM
thats normal. 40 is center. well,,, about 40. stock the factory book for 93 lt1 calls for 1 full turn. 3/4 turn is fine as well. i am using 1/2 turn which is what comp cams called for with there 1.6 rockers.
Old Sep 3, 2011 | 06:05 PM
pcarollo's Avatar
Great, thanks!
apatton305
82-92 V8 Tech
May 10, 2013 08:19 AM
skinut
Jan 4, 2012 09:32 PM
skinut
Feb 15, 2011 05:59 PM
bryns81z28
Jul 20, 2009 06:39 AM
