LT1/LT4 Tech 1993-1997
1994 Camaro Z28
Old Nov 23, 2010 | 08:52 PM
quinton1810's Avatar
Default 1994 Camaro Z28
I have a 1994 Z28 with a LT1. It has a magnaflow exhaust system, K&N cold air intake, high compression aluminum heads, and a high performance shift kit in the tranny (4l60e). On the drag strip it has a problem shifting when it is at full throttle, it revs to almost seven grand before it shifts but quits pulling at around 5500. I was wondering what would be the best programmer to put in it in order to be able to set my shift points?
Old Nov 24, 2010 | 07:40 AM
torque_is_good's Avatar
www.lt1pcmtuning.com
what heads do you have or are you simply describing the stock LT1 heads on the f bodies?
Old Nov 24, 2010 | 08:25 AM
5500 is were a lightly built lt1 would peak on the powerband. tig has given a link for a good tuning place but a tune is not going to do much if the trany has an issue. is this a car you built yourself or did you just get it? what kind of shift kit and who installed it?
David Kent
Nov 10, 2011 06:20 PM
wazowski
Sep 3, 2011 12:06 AM
andersonj
Mar 6, 2011 07:32 PM
sebi1990
Jul 13, 2010 04:35 PM
sabercatman22
Jul 5, 2010 07:46 PM
