LS Series Tech 1998-2002
HID's causing factory alarm to go nuts??
Old 06-01-2010 | 05:19 PM
KissMyTush's Avatar
Yeah, it was pretty funny when this was still going on. I remember we got out and when he locked it it did it's usual two chirps and then we took about 4 steps and then the horn started going nuts and the lights were flashing... We were both like, "WTF dude!" Lol!
Old 06-01-2010 | 06:38 PM
Massey's Avatar
Well I cant tell you what happened to the alarm but I can tell you that the fog lights are wired in a way that if you have the switch on and arm your alarm the fogs will flash. The HID ballast can be causing issues with the BCM. The relays in the BCM are not rated to handle the extra current that the ballast needs to energise the HID lights. Unless they are in use I would keep the foglights off.
Massey
Old 06-01-2010 | 09:02 PM
KissMyTush's Avatar
Massey
It wasn't the HIDs causing it. We got it fixed, but thanks for the input man.
Old 06-01-2010 | 09:50 PM
blue_thunder01's Avatar
Excuse me..WE?? i believe ME fixed it lol
Old 06-01-2010 | 09:54 PM
Massey
I actually think thats why one of the ballasts for the fog lights burnt already..
Old 06-01-2010 | 10:07 PM
KissMyTush's Avatar
Lol! Yes you fixed it!
Old 06-02-2010 | 11:30 AM
Massey's Avatar
One way to cure the ballast issue is to have a relay switch the ballast. Attach the coil side of the relay to the factory fog wires and then make a feed with a fuse from power to the HID ballast then the other side of the ballast to ground. If you need me to draw a schematic I will just let me know. You will need 1 relay for each ballast. Using the standard "fog light relay" like you find in the kits made by Blazer will handle the current just fine.
Massey
RedSled99
04-21-2013 08:48 PM
destroyer1362
08-23-2010 06:35 PM
mkdog9
03-28-2010 08:46 AM
MochaCaliGirl
08-06-2007 03:15 PM
Tom97V6
05-05-2006 12:13 AM
Quick Reply: HID's causing factory alarm to go nuts??
