LS Series Tech 1998-2002
Window & radio???
Old May 27, 2010 | 07:24 PM
blk01SS's Avatar
Default Window & radio???
when I'm driving sometimes my windows & radio stops working, like as if there is some kind of shortage. it seems to only do it when I drive over a bump or on the fwy. does any one here know how to solve this problem???
Old May 27, 2010 | 08:21 PM
The BCM provides power to both windows, and radio. Check the wires and connectors attached to it.
Old Jun 1, 2010 | 03:05 PM
RSSSCamaro's Avatar
Default Bcm
I have dealt with this on my own car once. I removed the BCM which is located behind the glovebox inside of a black box. You remove it, (kind of difficult) then open the box, and you will find three solder joints that crack for some reason. I reflowed them (got them hot and added a little solder) and reinstalled the BCM, that was six months ago, and I haven't had the issue again. Goodluck, I hope this helps.
Old Jun 2, 2010 | 12:07 PM
Massey's Avatar
Here is what RSSS is talking about. Just follow the directions in the how to and you will have no more problems with your radio and windows.
https://camaroforums.com/forum/93-02-general-41/body-control-module-repair-52062/
Massey
tarheel
Oct 6, 2014 10:09 PM
Chevyguy004
Oct 3, 2011 05:09 AM
lamppost
Sep 2, 2010 08:59 PM
arkomandos
LS Series Tech
May 5, 2009 03:22 PM
mountainman
Jun 6, 2007 09:31 AM
