LS Series Tech 1998-2002
HID's causing factory alarm to go nuts??
Old Mar 1, 2010 | 10:21 AM
blue_thunder01's Avatar
Default HID's causing factory alarm to go nuts??
OK, i installed HID's in my 01 SS over the weekend and shortly after that my factory alarm started going off all by itself...it has something to do with the panic because after i set the alarm it gives of something like a "warning cherp" and sometimes itll just start going off all by itself...has anyone who has installed HID's on their car ran into this type of problem? I asked a guy i know who is an HID freak and all he said was that "they can cause some weird stuff" but didnt give an idea on how to fix it..i installed HID's in the low beams and in the fog lights...i didnt put them in high beams cuz i figured i didnt need them...would installing them in the high beams fix this problem?? or could the alarm system just gone haywire on coincidence?? any of your ideas would be appreciated..
Old Mar 1, 2010 | 07:50 PM
Ok so i did some tinkering just now and i found out my problem wasnt caused by the HID's..it has something to do with the alarm itself...does anyone have a wiring diagram or know of a free place i can go to get some of the anti theft system?? Better question..does anybody know where the vibration sensor is located?
Old Mar 3, 2010 | 04:09 PM
Wac137's Avatar
I cant answer any of that but i would like to know the answer also, my alarm in my 02 goes off all the time.... if I open the door to get in or out I basically have 2-4 seconds to get the key turned or start the car or it will go off.. same thing if i try to pop the hatch or hood
Old Mar 4, 2010 | 11:48 AM
golieguy3000's Avatar
I recently redid my sound system in my 98 z28 and i saw a little black sensor that is by the spare tire. The spare is in the passenger side trunk area you will have to take out the plastic speaker panel. The sensor is on the wheel well and has a adjustment **** on it i think. I tapped it cause i didnt know what it was and a red light blinked and horn beeped, so i think that is one shock sensor i am not sure if there are any more in the but i assume there are. Good luck hope this helps
Old Mar 8, 2010 | 04:32 PM
Problem solved!! I put new tail lights in the car and after installing them no more problems..i know the tail lights themselves didnt have anything to do with it but i did remove the side panel and saw the shock sensor, messed around with the wires and hasnt given me any problems since..
Old Mar 8, 2010 | 05:47 PM
libertyforall1776's Avatar
Interesting, so where is that shock sensor located anyhow?
Old Mar 28, 2010 | 09:10 PM
Revoroller's Avatar
Like the other mentioned, if you take out the passenger rear speaker panel in the trunk there is a little black box that says alarm sensor or something like that on it and thats your shock sensor.
Old Apr 4, 2010 | 08:08 AM
adamcc91's Avatar
sits ontop of the rear passenger wheelwell i believe
Old Apr 4, 2010 | 08:09 AM
adamcc91's Avatar
ive seen that before but i never really knew what it was. I always thought it was something to do with the remote entry
Old Apr 9, 2010 | 07:02 PM
Carl Dan's Avatar
the factory shock sensor is behind the rear side panel on the pass side where the spare tire is.
