No start, please help
Old 07-27-2008, 09:22 AM
Chappie99's Avatar
Default RE: No start, please help
Is it a HEI dist? Did you remember to plug the wire harness back into the side of the cap? By any chance, did you forget to plug in the modual under the cap? Or did you forget to put one back in?
Old 07-27-2008, 02:29 PM
MadMikeZ28's Avatar
ORIGINAL: 78camaroz28
I cant post more than a line or two at a time for some reason so here it goes again.
Bought a 78 Camaro, supposedly with a 69 corvette 350. Did an oil change right away and found out that the dipstick tube was broken. No problem, ordered a replacement, wrong part came, returned it, wrong part again and again. So I fixed my old tube and reinstalled it. Now the first thing is, as far as I know GM didnt make a passenger side dipstick until 81, if this is true it cant be a 69 corvette motor.
Wow , you give a better description of your dipstick issue that on your no start. I think it would be safe to say that your dipstick will have nothing to do with your no start so you can eliminate that.
If it has the points ignition check and make sure they are opening and are not burnt. Also check the wire to make sure its not broken.
Old 07-27-2008, 06:46 PM
78camaroz28's Avatar
Ok, have tried rewiring the car several times, purchased a new cap rotor plugs wires and coil. All hei power related wires are plugged in and receiving power. There is spark and fuel.
Could a timing issue be the demon im looking for could it be something else.
There cant be but so many issues. What gets me is that the car was fine until the wires were replaced. I tried the old ones again just in case and same thing.
Old 07-27-2008, 10:05 PM
MadMikeZ28's Avatar
Use the correct post for #1 on the cap, on the cylinders, clockwise, 1357 on the left, not 1234?
Old 07-27-2008, 11:26 PM
OK, putting on my Sherlock Holmes hat brings the answer to being elementary my dear Watson. Your engine did run, then you changed the wires, now it doesn't run? Hmmmm...I got it! It has to do with the wires and how they're installed. Now that was easy!
So try checking everything, again...
With the #1 cylinder at TDC, compression stroke, make a note of which terminal on the distributor cap the rotor is pointing to. Your #1 plug wire goes there. The rest of the plug wires go on the cap in a clockwise manner following the 1-8-4-3-6-5-7-2 firing order.
Your cylinders are as follows:
Drivers side bank starting from the front, 1, 3, 5, 7
Passenger side f-b, 2, 4, 6, 8.
If you're getting spark and fuel, and the only thing you changed (initially) was the wires, then it should fire up.
Old 07-28-2008, 12:11 AM
MadMikeZ28's Avatar
How are you able to post so much without an error message. That is basicly what I was trying to say but have to keep it all short. [:@]
Old 07-28-2008, 12:16 AM
I held my breath and crossed my fingers. That one surprised me too.
Old 07-28-2008, 12:19 AM
Lately, I've been posting screen prints for the wordy ones. Now this time, I couldn't even get these two on at once!
Old 07-28-2008, 05:59 PM
Wheh, finally got it! Did the tdc trick with the the #1 plug. Found all the wires to be two posts counterclockwise of all the schematics that Ive tried. Took my 3 days but finally got it!!! Thanks everyone.
  #20
Old 07-28-2008, 06:02 PM
Ok, now for the next problem, none of my gauges work except for the Speedo and Tach. Was debating getting the new dash panel with gauges prewired that year one sells. Anyone seen it or have it? Thoughts?
Lakatrae
03-29-2014 10:59 AM
rdb357
03-30-2008 08:25 AM
JTyler
08-31-2007 10:21 PM
coco
08-13-2007 10:33 AM
Quick Reply: No start, please help
