86 V6 Won't start
Old Aug 25, 2007 | 02:20 PM
JTyler's Avatar
Default 86 V6 Won't start
Hey guys,
A buddy of mine has a 1986 2.4L(?) Camaro that he just bought. Got it home and now it won't start. Recharged the battery, replaced the starter, still nothing. When he turns the key one click, the lights come on and such, but when he turns it to the start position there's nothing. He gota new igniton switch, but I know they can be a pain in the butt to switch, so is there anything else you guys reccomend checking out before he digs into that? If not, what does he need to do to change that? Thanks
Old Aug 25, 2007 | 02:23 PM
02StanGT's Avatar
Default RE: 86 V6 Won't start
Does it even turn over? Are all the cables hooked up correctly? If so are they corroded in anyway? These are a few things to maybe check.
Old Aug 25, 2007 | 02:57 PM
JTyler's Avatar
No, won't turn over at all. Not even a hint. The cables are all good, no corrosion, seems perfect. Thats why I'm so lost on it.
Old Aug 25, 2007 | 03:21 PM
1990CamaroRS's Avatar
Fancy Sparkle
check the start sylonoid(sp) that might be the problem
Old Aug 31, 2007 | 08:02 PM
Chappie99's Avatar
He replaced th starter....Double check your battery cables. A bad ground will do just that. It will power up the asscesories but will short out when you apply too much of a draw.
ORIGINAL: 1990CamaroRS
Old Aug 31, 2007 | 10:21 PM
Fancy Sparkle
ORIGINAL: Chappie99
start sylonoid and the starter are two different things
Lakatrae
Mar 29, 2014 10:59 AM
TAVS
Aug 30, 2009 02:59 PM
rdb357
Mar 30, 2008 08:25 AM
coco
Aug 13, 2007 10:33 AM
