want's to start... but won't.
Old Aug 9, 2007 | 09:42 AM
coco's Avatar
Default want's to start... but won't.
Here is my list of parts, but still won't start. Fuel pump, cap, rotor, idle air control valve, relay, regulator, plugs andgaskets for the throttle body. If I dump fuel into the tbi it will start and run till the gas is gone. I can see fuel coming out of the injectors, but it still won's stay running. I am showing no codes. I am wondering if it isn't the injectors. It has the right fuel pressure. Anyone have anything like this happen to them?
Old Aug 9, 2007 | 06:07 PM
Default RE: want's to start... but won't.
Did you replace the fuel filter?
Old Aug 9, 2007 | 06:15 PM
Chappie99's Avatar
If there is proper pressure and the injectors are working, you say if you add gas it will run until its gone? So then it is getting spark, double check that fuel pressure. My only other thought is that the engine doenst have a good enough ground so that the starter isnt turning fast enough. but if you said you got it to run????????I am puzzled?????
Old Aug 9, 2007 | 11:28 PM
Goodfella's Avatar
shot in the dark here:
fuel pump relay fuse?
Old Aug 10, 2007 | 08:53 PM
02blackonblack's Avatar
I bet your disty is not in time enough. I just got my 86 iroc started for the first time in 2 years after rebuilding the top half of the motor and the smallest turn of the distributor determines whether it will stay running or not.
Old Aug 13, 2007 | 10:33 AM
coco's Avatar
I got her running again. The wrong fuel pump ruined my injectors, but she is running really good again now. Thanks for all the help guys.
Lakatrae
Mar 29, 2014 10:59 AM
TAVS
Aug 30, 2009 02:59 PM
rdb357
Mar 30, 2008 08:25 AM
JTyler
Aug 31, 2007 10:21 PM
