New AC clutch - now no power to the clutch
Old Aug 5, 2009 | 02:45 PM
therronsr's Avatar
Default New AC clutch - now no power to the clutch
1997 V6 - Recently I had my AC clutch start shaving metal. It was working though. I disconnected the plug and swapped out the clutch and its parts with new. I then put it all back to gether. Fired it up and clutch will not kick in. I tested all the fuses and relays and all is good. however I still do not get power to the AC clutch. Could it be a bad HI or LOW sensor? I only see 1 sensor and it has 3 wires and it appears to be on the HI side. Any help?
Old Aug 5, 2009 | 08:13 PM
Only one sensor on these models. May be a bad cluch, have you tried feeding power directly from the battery to the cluch? Use a fused jumper to prevent fire. Also check grounding, there should be a black wire going to ground.
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
