clutch squeal with clutch not pressed
Old Jun 28, 2012 | 02:53 PM
dogdog130's Avatar
Default clutch squeal with clutch not pressed
hello i got a 1995 camaro 5 speed well today i was driveing and for some reason i rolled down my window and turned down my music and i can hear a lowd squeal from the clutch but if i push it in no squeal any ideas it got worse since this morning had to drive it home from work
Old Jun 28, 2012 | 04:15 PM
dogdog130's Avatar
no ideas people
Old Jun 28, 2012 | 04:28 PM
If you have a worn and squeaky throwout bearing, and it's riding free-wheel on the pressure plate, that could be the squeak you hear. Then the noise would go away when you put a load on it (pedal down). Keep an ear out for it though. If it is the bearing going bad, it'll start making a nastier grinding sound when you push the pedal in.
therronsr
Aug 5, 2009 08:13 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
