Clutch noise, but no clutch problem...well not yet anyway
Old Nov 8, 2007 | 08:23 PM
Rise65's Avatar
Default Clutch noise, but no clutch problem...well not yet anyway
Hi, I'd like an opinion or two. I own a 98 Z28. Very recently, the clutch has started making significant whining noises when the clutch is depressed, there is also a bit of a grinding sound when sitting at a red light, you can actually feel it in the pedal. The clutch seems to be working fine, no upshift or downshift problem,,, just some ugly sounds when the pedal is pushed in.
The clutch on this car owes me nothing, I am approaching 290,000 kms on the original equipment, just wanting to know what it is I am hearing..
I expect I will be replacing the entire clutch, unless someone tells me something I should know.
Thanks.
Old Nov 8, 2007 | 10:58 PM
Default RE: Clutch noise, but no clutch problem...well not yet anyway
Your throwout bearing is going bad.
cdnturboz
Aug 30, 2012 10:50 AM
imcdowel
Dec 17, 2010 10:35 PM
Envisi0n91
Mar 6, 2010 05:42 PM
d98camaro
Mar 9, 2008 12:09 PM
VTownSuzieQ
Dec 8, 2006 07:24 AM
