LT1/LT4 Tech 1993-1997
clutch noise
Old Dec 16, 2010 | 12:28 AM
imcdowel's Avatar
Question clutch noise
so i just replaced my clutch tob and pressure plate about 6000 miles ago and everything was fine... now i just noticed, that when i was in nuetral clutch engaged it makes a very slight grinind noise. like before but much much quieter. if i push in the clutch it goes away. ive only heard it this first time. this is my everyday driver for now but im not hard on it at all. other than occasionaly dumping the clutch from the revs getting stuck (working on finding out what that is) its never really romped on. is my pressure plate already going bad?! how?! or is this normal....
Old Dec 16, 2010 | 06:01 AM
i would suspect the throw out bearing or pilot bushing/bearing.
Old Dec 16, 2010 | 09:32 AM
BasicConcepts's Avatar
Technical User
agree with craby
Old Dec 17, 2010 | 03:59 PM
imcdowel's Avatar
you think itll have to be replaced again? ill pull it apart and look at it some time this week. what would cause my tob or pressure plate to go out so fast again?
Old Dec 17, 2010 | 06:20 PM
faulty tob, not adjusted right, pilot bearing faulty or not changed when clutch was changed. do you ride (hold foot on peddle) the clutch when you drive?
Old Dec 17, 2010 | 10:35 PM
imcdowel's Avatar
no i dot ride the clutch i just let it neutral. if it wast adjusted correctly i will take it back to my old mechanic that installed it and see whats up. i helped install the entire thing so it looked right but i could be wrong.
jweb47
Apr 24, 2015 03:42 PM
cdnturboz
Aug 30, 2012 10:50 AM
d98camaro
Mar 9, 2008 12:09 PM
Rise65
Nov 8, 2007 10:58 PM
VTownSuzieQ
Dec 8, 2006 07:24 AM
