LT1/LT4 Tech 1993-1997
clutch help! t56 clutch fork hitting plate
Old Dec 21, 2008 | 12:59 PM
bluegreenta's Avatar
Default clutch help! t56 clutch fork hitting plate
I have a 96 6speed trans am, the clutch fork started hitting the outside edge of the pressure plate. I replaced the clutch disk and pressure plate, and had the flywheel resurfaced. but the fork is still hitting the outside edge of the pressure plate. Any ideas on how to fix this? I would like to hear an idea that dont end up with me pulling the transmission.
thanks for your help!
Old Dec 21, 2008 | 03:25 PM
Default RE: clutch help! t56 clutch fork hitting plate
Did you replace the throwout bearing?
Old Dec 21, 2008 | 09:24 PM
yes I did replace it. I have it fixed now. turned out being the bolt on the clutch fork, I took out the slave cyl and pulled the fork down and tighted the bolt on the fork. fixed it right up.
everything works perfect now and I dident need to pull the transmission!
WOOT!
MKCoconuts
Jul 6, 2015 11:43 AM
IDCamaro1994
Oct 29, 2013 04:21 PM
fitman
Sep 1, 2011 08:08 AM
locotrician
May 16, 2009 11:18 PM
macpeppers
Jun 15, 2007 06:54 AM
