therronsr |
08-05-2009 02:45 PM |
New AC clutch - now no power to the clutch
1997 V6 - Recently I had my AC clutch start shaving metal. It was working though. I disconnected the plug and swapped out the clutch and its parts with new. I then put it all back to gether. Fired it up and clutch will not kick in. I tested all the fuses and relays and all is good. however I still do not get power to the AC clutch. Could it be a bad HI or LOW sensor? I only see 1 sensor and it has 3 wires and it appears to be on the HI side. Any help?
