it dont work
Old May 8, 2007 | 11:47 PM
bluecamaro's Avatar
Default it dont work
I just bought a 86 camaro with a 2.8, The fuel pump wouldnt turn on. I pulled back the carpet and discoverd a hole so i harwired the fuel pump in not it works.Now im pretty sure the injectors arent working. could there be a bad realy or fuse somwhere all the fuses are good i dont kno which relay to change. could the ecu be bad?. It has plenty of fuel pressure
Old May 9, 2007 | 11:19 PM
RatMotor's Avatar
Default RE: it dont work
You really need to learn some grammar and spellingskills.
How could anyone make heads or tails of that post?
RM
Old May 10, 2007 | 11:23 PM
jdubs1813's Avatar
I agree.
What I think he's say is that his fuel pump wasn't work, he hardwired it, and now it does work... Or at least he thinks it does... Then he said his fuel injectors aren't working he thinks. He also wants to know if it could be an ECU problem.
Only thing is that he never posted what the problem is in the first place... It won't start? Run? Runs rough? I have no idea...
Try changing your fuel filter first before jumping under the hood and taking everything apart. Is it Multi-port... right? or is it TBI?
Franksflying1
Sep 7, 2009 03:46 PM
nazariol
Jul 17, 2009 10:36 AM
camarojunkie21
LS Series Tech
Apr 3, 2009 10:43 AM
speedfreak1000
Mar 11, 2009 06:46 AM
SilverBullet55
Mar 10, 2008 03:19 PM
