it dont work
I just bought a 86 camaro with a 2.8, The fuel pump wouldnt turn on. I pulled back the carpet and discoverd a hole so i harwired the fuel pump in not it works.Now im pretty sure the injectors arent working. could there be a bad realy or fuse somwhere all the fuses are good i dont kno which relay to change. could the ecu be bad?. It has plenty of fuel pressure
RE: it dont work
You really need to learn some grammar and spellingskills.
How could anyone make heads or tails of that post? RM |
RE: it dont work
I agree.
What I think he's say is that his fuel pump wasn't work, he hardwired it, and now it does work... Or at least he thinks it does... Then he said his fuel injectors aren't working he thinks. He also wants to know if it could be an ECU problem. Only thing is that he never posted what the problem is in the first place... It won't start? Run? Runs rough? I have no idea... Try changing your fuel filter first before jumping under the hood and taking everything apart. Is it Multi-port... right? or is it TBI? |
