Headligths dont work!
Old Jul 16, 2009 | 11:44 PM
nazariol's Avatar
Default Headligths dont work!
So today i went to turn on my car after work adn the headligths dont work !
the bulbs are both good!
I checked the fuses but he engine fuse box where the fuses are supposed to be never had any! does anyone reccomend anything! please !! thanks guys!
Old Jul 17, 2009 | 12:04 AM
allright its a contest. i guess a a a 95 z28. there is a fuse box on the driver side of the dash by the door hinges. should be a fuseable link in that line somewhere.
Old Jul 17, 2009 | 09:31 AM
nazariol's Avatar
Default Re headligths don't work
How do I do that my friend how can I check for that
Old Jul 17, 2009 | 10:36 AM
open the driver door and look on the side of the dash. there should be a fuse box there. check it first. im not sure about the location of the fuseable link. because the headlight switch is hot or powered all the time it needs a fuseable link to be sure there is a weak link in the wireing system in case of a direct short. it should be on a wire in the area of the electrical junktion box. its a long lump in the wire. best way to check the link is to get a test light and see if u get power to the fuse box by the door. if u do then the link is fine and the problem is in the fuse or switch. have u checked for juice at the headlight switch?
jcmstg7
Nov 10, 2009 01:50 PM
camarojunkie21
LS Series Tech
Apr 3, 2009 10:43 AM
speedfreak1000
Mar 11, 2009 06:46 AM
SilverBullet55
Mar 10, 2008 03:19 PM
bluecamaro
May 10, 2007 11:23 PM
