Over heating need some help
Old Jun 16, 2006 | 10:41 AM
Withered962's Avatar
Default Over heating need some help
Hey, just got a 88 IROC-Z(350)... put in new thermostat n gasket, new heat sensor still over heating and spilling engine coolant everywhere... infact i had so much pressure my heater control valve broke... any ideas anyone?... reply soon please
Old Jun 16, 2006 | 12:10 PM
akohnz's Avatar
Default RE: Over heating need some help
If you have changed the coolant lately you need to maker sure there are no airpockets in the system, bleed it out. If you have one the car will overheat rather quickly and cause the coolant to boil over.
akohnz
Old Jun 16, 2006 | 03:55 PM
changed the collant and had no air pockets... still dunno what's wrong with it =/
Old Jun 16, 2006 | 07:21 PM
IMO you car eithe has a blown head gasket or a plugged up radiator. A trip to a good radiator shop can test the coolant for combustion gases and check the status of your radiator.
Old Jun 22, 2006 | 01:37 AM
turns out it was a broken O2 sensor... otherwise now my baby is running fine... =D
hb0180
Aug 28, 2011 02:02 PM
mrsdeano
Sep 23, 2010 10:35 AM
pkelly94z28
Jul 27, 2009 01:16 AM
GoofieJ21
Sep 24, 2007 07:32 PM
CAMAROcruiserFL
May 2, 2005 12:13 AM
