Which engine????
Old Nov 27, 2009 | 08:27 PM
thatcamaro's Avatar
Default Which engine????
hey everyone. ive got a 79 camaro with a 305 in it rite now. i wanna take it out and either put a 327 or a 350 in it. the problem is is that the 350 is just a bare block so i have to get everything to get it going. the 327 is complete but its been sitting under a cover behind a barn for along time so it probably needs to be rebuilt also. Which one should i put my money into?
Old Nov 27, 2009 | 11:13 PM
NYH1's Avatar
In my opinion the 350 is a better engine unless it's going into a "numbers matching" car/truck. They both have 4.000 inch bores. The 327 has a 3.250 inch stroke crankshaft. The 350 has a 3.480 inch stroke crankshaft. The longer stroke generally makes more torque. It also usually makes both horsepower and torque at a lower RPM range.
Most of the SBC cam spec's you see are based on a 350. There are exceptions. I'm sure others will have different opinions.
Old Nov 29, 2009 | 12:45 AM
nelson.jones07's Avatar
Better you find this answer from the service provider or on several related websites
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
