Help needed. Spraying oil.
Old Apr 10, 2011 | 01:33 PM
  #31
Massey's Avatar
There is no gasket behind the tensioner. If memory serves me right one of the bolts that go into the head go right into the water jacket. I would have to look at one of my heads sitting at home. If that is the case then put some sealer on the threads and tighten it back up. It could also be the tensioner, hose, or the freeze plug that is right on the face of the head.
If you do take the tensioner assy off make sure you replace the plastic elbows and use some grease or sealer to seal them back up when you put the tensioner back on. Also if the plastic pieces break in the water pump or intake make sure you dig out the broken pieces or you will continue to leak.
Massey
Old Apr 10, 2011 | 02:31 PM
  #32
Tom70's Avatar
Default Update
Ok so I got the tensioner off and I believe it is leaking from the HVAC heater hose fitting and this little place.
Does anyone have a suggestion for how to patch this hole, or can I order just that little piece that screws into the side? Maybe JB Weld? I don't know if it would hold well enough though.
Old Apr 10, 2011 | 02:40 PM
  #33
Tom70's Avatar
Massey
Just now saw this. Thanks. I already took the tensioner pulley off and bought the elbows. I didn't get some sealer but I'll be sure to pick some up thanks. And I have almost all of the old piece out except for the very last little bit of the one that is below the TB. It's being a pain in the butt.
Old Apr 10, 2011 | 11:41 PM
  #34
Massey's Avatar
I used some bearing grease on mine and so far no leaks. You are better off just getting a new tensioner assembly, especally after the hack job that was done to it before with the threaded heater hose mess you took off.
Massey
Old Apr 11, 2011 | 08:01 AM
  #35
Tom70's Avatar
Massey
Do you think the JB Weld would be a good enough temporary fix until I can afford the assembly since I'm running low on cash at the moment and don't have anything to drive? I found the assembly online for around $60 plus shipping. I'll try to look around and see if I can find one in a junkyard for less. Thanks for the help.
Old Apr 11, 2011 | 11:09 AM
  #36
Massey's Avatar
Dont junkyard it! And why buy it online? Go to your local O'reilly or Advance store they usually stock it or can have it for you same day, for the same or less. JB weld might work but you are going to have to get that alot cleaner for it to hold properly.
Gates 38289 - Belt Drive Tensioner | O'Reilly Auto Parts
Massey
Old Apr 11, 2011 | 11:36 AM
  #37
That part with a hole in it is a threaded plug. Heat it up with a torch if you need to, back it out with an Allan wrench, chase it down to your local hardware store plumbing section and buy a matching plug, put a couple wraps of teflon tape or pipe dope on the threads, then crank the new plug in. I wouldn't trust J-B weld to hold your existing one for very long.
Old Apr 11, 2011 | 11:54 AM
  #38
^^^ thats what i thought but couldnt tell if it was a shadow or a hole. and if that plug it getting ate up then the other soft pluggs in the system may be getting weak as well so keep an eye out for any other signs of leakage.
Old Apr 11, 2011 | 01:34 PM
  #39
Tom70's Avatar
Thanks guys I'm going to see what I can do. I plan on replacing it when I can, but I'm gonna see how my finances play out this week. I may give removing it and replacing it a try, but I don't have access to a blow torch so I may not be able to remove it. I won't be able to do anything until this weekend anyway.
Old Apr 14, 2011 | 08:49 AM
  #40
Tom70's Avatar
UPDATE: I ordered the tensioner assembly and I'm going to pick it up tomorrow afternoon and I will hopefully get the kit from v6fixit today or tomorrow as well. So I'm praying that she will be up and running tomorrow or saturday. Thanks for all of the advice guys.
adam.howard450
Jan 23, 2015 08:32 PM
snp
Apr 30, 2014 08:10 PM
motobro
Apr 8, 2012 06:16 AM
Clutch_Z28
Mar 24, 2008 06:32 PM
GMDCAMARO
Nov 21, 2007 01:41 PM
