Engine swap finished with problems
Old Apr 6, 2010 | 04:40 PM
thecamaroguy13's Avatar
Default Engine swap finished with problems
Hello I recently finished an engine swap on my 1995 3.4L camaro 5spd. I have a few issues that i need some help with. While driving if i push the clutch in at higher rpms, the rpms dip all the way down to 0 then the car turns off unless i keep the rpms up by giving it some gas. The speedometer also does not work. There are also 2 plugs inside the engine bay that need to be plugged in, so it could possibly be because of those wires/plugs. Any help appreciated, thanks.
Old Apr 6, 2010 | 04:56 PM
osduck5's Avatar
Can you post a pic of the wiring connectors that need to be plugged up? For the speedometer, did you plug the wiring harness into the speed sensor on the tranny?
Old Apr 6, 2010 | 05:11 PM
sure ill take some right now, gimme 5 and i think i havent plugged anything into the tranny yet.
Old Apr 6, 2010 | 05:17 PM
how do i add my pics?
Old Apr 6, 2010 | 05:31 PM
osduck5's Avatar
You can add them to photobucket and insert link in your post or click on "manage attachments" when you do a reply, on my computer, I have to scroll the screen down to see that. It is below the icons.
Here is the official "how to" link telling you how
https://camaroforums.com/forum/camaro-forum-issues-7/how-embedding-your-photo-post-19612/
Old Apr 6, 2010 | 05:43 PM
https://camaroforums.com/forum/showthread.php?t=19612
Old Apr 6, 2010 | 06:02 PM
osduck5's Avatar
Sorry, I don't know about those. The top one looks like the one that plugs into the sensor that is in the plastic air duct goiing to the throttle body. Double check for any sensors near where the wires are, you may have to get under the vehicle looking up on each side of the engine. Hopefully someone else will have better knowledge of the 3.4 sensor locations and wiring harness.
smbigfoot
Aug 14, 2012 07:36 AM
3800_seriesII
Aug 14, 2012 07:24 AM
smbigfoot
Jul 9, 2012 08:57 AM
SSV6
Jun 17, 2009 07:58 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
