starting problems with my 89 rs with 5.7 tpi swap
Old Jul 8, 2012 | 06:35 PM
smbigfoot's Avatar
Default starting problems with my 89 rs with 5.7 tpi swap
ok so i had just done this 5.7 tpi swap in my 89 rs, after installing the engine, wiring harness, and computer and hooking everything up, the car wont start, i tested the old starter and it was bad and was replaced but still cannot get the car to turn over by key, i think im running into a problem with the VATS PASSKEY system, the key does not have the chip in it, i beleave it had fell out when when the v6 was in it it would still turn over.(only when the v6 was in), the security light does not come on at all, so im getting clueless on this problem.
Thanks!!
Old Aug 14, 2012 | 07:36 AM
Edwardgp's Avatar
I believe they have a VATS bypass kit you could try.
smbigfoot
Jul 9, 2012 08:57 AM
licnep
Jun 4, 2010 10:13 AM
EasternStryker
Feb 28, 2010 09:57 AM
CamaroTeen
Jan 13, 2010 11:01 PM
jdubs1813
May 22, 2009 08:40 PM
