94 engine issues. Please help
Old Jun 3, 2021 | 04:18 PM
FlyingCowboy's Avatar
So it's running worse everyday. Gutted the cat. A little difference but not much. EGR is black but orifices are clear.
Lots of back firing in exhaust and smells very rich. Rough idle and missing at all power ranges. so I've ran it some and maybe drove it 45 miles. Pulled the plugs. 4 of the insulator's are white, 1 looks tannish and 1 is soaking wet. This is after sitting for about 7 hours. These are rebuilt injectors that I just put in when I fixed the oil leaks. Is the one plug wet because the plug isn't firing or that the injector is dumping fuel all the time? Thats the question and why are the other insulator's nice and white. The grounding post shows signs of detonation but I would think I'd see some discoloration on the ceramic.
Hope someone can shed some light.
Old Jun 4, 2021 | 12:34 AM
did you check for spark at all the plugs? lots going on so very hard to say what it is. test compression on the wet plug cylinder, how much blow by you getting?
Old Jun 4, 2021 | 08:15 AM
cwilt's Avatar
Pull the wet plug. Install the plug in the wire and ground the plug, have someone crank the engine and see if it sparks. If it sparks its probably your injector.
Old Feb 4, 2022 | 08:50 PM
cwilt's Avatar
I know this is 6 months old, but did you ever get it fixed up?
Old Aug 13, 2022 | 08:47 PM
fazeelnawaz432's Avatar
I am new in this forum. I have some questions about this forum. These questions are shown underneath:
https://camaroforums.com/forum/93-02...o-start-86309/
My question is about this thread. If you have any information about this thread. Tell me below. I am very confused about that.
pcarollo
Dec 24, 2013 07:56 PM
CZimmer
May 15, 2012 06:49 AM
jmutter
82-92 V6 Tech
Aug 29, 2011 10:42 AM
retroj23Z28
May 25, 2009 02:09 PM
magno453
Oct 16, 2007 09:10 PM
