Replacement for 1994 T-56
Old Apr 24, 2020 | 12:56 PM
oldvetteguy's Avatar
Default Replacement for 1994 T-56
Back in 2002 I built a 1962 Corvette restorod using a T-56 6 speed transmission from a 1994 Camaro, gear ratios are 2.66, 1.78, 1.30, 1.00, 0.74, 0.50. I would like to replace the transmission with a new one, but I have been told that this transmission is no longer available. Just wondering if anyone on this forum knows of a source for a new transmission like the one I have. If not, how about a recommendation on someone to rebuild the one I have?
Thanks,
Charles
Old Apr 24, 2020 | 06:29 PM
Old Apr 25, 2020 | 09:33 AM
Thanks for the information.
I talked to someone from Silver Sport and their Tremec Magnum T-56 is not what I would call a "direct replacement". The Tremec has a different hydraulic clutch arrangement, different driveshaft output splines, and a different bellhousing to fit my engine. The "direct replacement" applies to LS engines, not my iron block 350.
Charles
Old Apr 25, 2020 | 09:48 AM
Charles
Well it's about the only option for new from what I've seen,is there a reason yours can't be rebuilt?
Old Apr 25, 2020 | 11:06 AM
Probably not. Anyone know a reliable transmission rebuilder in central NC - Winston-Salem, Greensboro, Charlotte area?
Old Apr 26, 2020 | 09:37 AM
MKCoconuts's Avatar
You can order the magnum with the correct bellhousing. All you would have to do is change to internal hydraulic clutch and find a 31 spline (GM T56 are 27 spline output) yoke to connect to your drive shaft. Everything could be ordered through Summit racing.
Is there a reason yours needs rebuilt?
carrmann
Dec 9, 2017 04:28 PM
bad436z28
70-81 Transmission & Differential
Feb 22, 2012 09:03 PM
JLink3
LS Series Tech
Jun 8, 2009 05:29 PM
JLink3
LS Series Tech
Apr 28, 2009 06:37 AM
meteoralp45
Feb 8, 2008 02:07 AM
