t-56
Old Feb 22, 2012 | 07:06 PM
bad436z28's Avatar
Default t-56
is the t-56 really that much stronger than the st-10,is the price and hassle of swapping the t-56 really worth it over the super 10.
Old Feb 22, 2012 | 07:21 PM
rydeer's Avatar
You just wanted to be first??
Old Feb 22, 2012 | 07:48 PM
KissMyTush's Avatar
Check out Tick Shift dot com. They can build a T-56 for you to basically anything you want! I had mine built by them and it was amazing! I've also seen stock transmissions run up to almost 500RWHP and it was a DD/Weekend drag car. Just depends on how well maintained and what condition they're in I guess. But they have great build potential.
Old Feb 22, 2012 | 07:50 PM
Z28Camaro98's Avatar
my 98 z28 had a t-56 put in, because the original went boom! the new one was rated for a 700 ft/lb motor.
Old Feb 22, 2012 | 07:55 PM
KissMyTush's Avatar
Mine was rated for 700RWHP as well. I bought everything from Tick and rebuilt it.
Old Feb 22, 2012 | 08:09 PM
bad436z28's Avatar
rydeer im not trying to be first,not even sure that i want one,was just wondering how hard the swap is and if it worth the hassle of swapping it.the one im really intrested in is the tko 600 but not sure i wanna spend that much money,how hard is it to swap a t-56 into a 2nd gen
Old Feb 22, 2012 | 09:03 PM
bad436z28's Avatar
just read a few threads on swapping the t-56 in a second gen and u have to cut up the tunnel to get it to fit,no thank you,i think im just gonna save up for the tko 600,right now im just gonna run the borg warner st-10,we will see how well she holds up.
