Old Aug 12, 2013 | 03:12 PM
  #611
WIspartan1026's Avatar
May 2013 ROTM
Yeah, they're Pacesetters. Got them for $285 slightly used, noticed the flaking about a year later. Stored winters, never driven in salt/snow since I've had them.
Old Aug 23, 2013 | 02:31 PM
  #612
May 2013 ROTM
and I am +1 boat anchor
Old Sep 12, 2013 | 08:56 PM
  #613
May 2013 ROTM
Made some decent progress tonight. Got the intake manifold and valve covers switched over. Next up is the timing cover.
Old Sep 18, 2013 | 08:51 PM
  #614
May 2013 ROTM
installed the timing cover tonight. next step: optispark and water pump.
Old Sep 18, 2013 | 09:08 PM
  #615
woh do you only get an hour or so a nite?
Old Sep 18, 2013 | 10:13 PM
  #616
May 2013 ROTM
Usually I can spare a bit more than that. After work I drive 20 or so minutes to the shop, work for 2-3 hours tops, then drive 25 minutes back home. Tonight took a bit longer because I had to make an extra trip to pick up some thread locker for the cam sprocket bolts (of course, it's never at the first place you stop), and I was kinda confused about the CPS reluctor, so I had to spend some time researching that.
Old Sep 28, 2013 | 04:43 PM
  #617
May 2013 ROTM
Things are coming together slowly but surely. Did some work on the accessory bracket.
As it looked coming off the car:
After cleaning it up a bit (sorry for crappy pic, but you get the idea):
Painted up:
It will be going on the new engine on Monday.
Old Oct 1, 2013 | 08:34 PM
  #618
May 2013 ROTM
Getting there....
Looking at October 19 for the drop-in date
Old Oct 6, 2013 | 03:08 PM
  #619
May 2013 ROTM
Getting closer and closer! My dad made the trip from Wisconsin this weekend to help me out, and we made some nice progress.
Got the trans installed, swapped over the wiring harness, and a couple other things. Pretty much all that's left is to coat and install the longtubes and to put on the balancer/pulley (didn't get the threaded rod from McMaster-Carr in time).
Found this hole melted into the wiring harness. Must've been touching the headers. Miraculously, it didn't melt through any of the wires.
We also installed a 1LE sway bar. Here's why:
We were also going to install an LS1 steering shaft, but I didn't know about the fact that it's oriented slightly differently than the stock steering shaft. I didn't have time to pound it out and separate it and reindex it, and I didn't have access to a welder. This and the fact that there was zero play in my rag joint, so I put the old one back in. Still on the fence if I'm going to install the LS1 one yet or not.
So pretty much everything's ready for the engine to go back into the car. My next free Saturday is the 19th, so I'd like to do the install that day.
Old Oct 17, 2013 | 03:13 PM
  #620
May 2013 ROTM
So last night, I removed the oil pan from my old engine, just to see what it looked like inside. Surprisingly, I didn't see as much carnage as I was expecting. I did find this piece of aluminum:
And this piece:
Couldn't tell where they came from, though.
