Who knows anything about wiring subwoofers.
#23
I have a single 12" Pioneer in a 1.5 cubic foot sealed box. You don't have to replace the door speakers but it's recommended if you're running a decent sub setup. A set of decent coaxials will do the job. I recommend RE Audio. They have the best sound quality I've ever heard and Ive worked at two automotive audio installation shops. RE Audio always has a perfect blend of highs and mids while your subs will push the lows. You can get RE Audio speakers for like $40-$60 on sonicelectronix.com I believe. That's where I got mine but I don't remember exactly how much they cost. By the way, your car takes a 6.5" speaker if you didn't already know.
#25
Thanks for your help It will help me when I Install these things. One more thing would be as far as sanding the ground cable. Will I sand the ground cable Itself or the cars bolt along with the base where the bolt would normally be. I am confused on what pieces to sand.
#26
I think one of the speakers In my car Is blown because It has a rattle like fuzz sound to It. I found this deck online. I am wondering If this deck I found will work for my amp. Could I only replace the one blown speaker with one of the ones that comes In this bundle or will It sound funny then I have to replace all the speakers. Walmart.com: Kenwood KDC-148 CD/MP3 200W Receiver with pair of 6.5" 2-Way Speakers, Bundle: Auto Electronics
#27
Alright I have seen different answers. Your saying that I only sand the bolt. I should sand the metal part of the car where the bolt would normally be sitting on. But only sand the bolt dont sand the terminal or metal where the bolt would normally sit on.
#28
Sand everything that the wire will be touching to insure a good connection. That bundle pack will do nicely. Use both speakers in either the rear or front depending on where the blown speaker is. I would put two good stock speakers in the back and the new ones in the doors. You'll get the best sound that way.
#29
#30
This box Isnt the same as mine but looks close but a real picture of mine Is on the first page Amazon.com: Atrend B Box Series 10Cb Enclosure for 10-Inch Camaro/Trans AM 1994 and Up (Dual): Electronics .
