squeals when I turn left
Since it's rhythmic to wheel rotation, it's likely to be the pads moving against the caliper bracket. Hit the brakes, and the pads stop moving.
Try this stuff, you only need to coat the contact areas: Disc Brake Quiet
Finally figured this one out! Found my drivers side rear caliper guide pin was loose and because of that it was missing most of its caliper grease. Tightened it, greased it, reassembled it and the noise is finally gone! I am ecstatic!
