Service Engine Soon Flashing.
Old Jun 1, 2011 | 10:04 AM
  #41
stainless1911's Avatar
Do I have to replace the oil pan gasket too?
Old Jun 1, 2011 | 04:57 PM
  #42
3800camaro's Avatar
No you don't aslong as you don't rip it. Its not holding any pressure so it can be reused.
Old Jun 1, 2011 | 10:10 PM
  #43
Thank goodness, Last thing I want to do, is pull the engine just to change a gasket.
Whan I changed the oil filter, I found a plug wire that was completely burnt through, lying against the drivers side cat. Could that throw this particular code? I changed that wire, and Im going to check and change the others in the next few days. Figured I'd put new plugs in it too. The wires were new, only a few hundred miles, I guess I should have been more careful putting them in.
Old Jun 1, 2011 | 10:16 PM
  #44
sure seems to me a bad plug wire could and would through a misfire code.
Old Jun 1, 2011 | 10:25 PM
  #45
It would sure be nice if that's all it is, I really dont have the money for this $#!+ right now.
I should put the timing chain in it though, 165K, and I dont know if it was ever driven hard.
Old Jun 2, 2011 | 02:28 AM
  #46
they have pretty good timing chains. i changed mine at 100k and it looked close to new. they are a bit lose new.
Old Jun 2, 2011 | 10:59 AM
  #47
I was afraid of losing a motor because of not maintaining a 30$ part.
I sure wish I had you guys around when Im actually working around the car.
Old Jun 12, 2011 | 10:17 AM
  #48
Bosch platinum 4 gave me a PO300 code, random misfire. Changed ONLY the plugs to AC Delco, and the code is gone. Car runs fine.
Triangle12
Mar 8, 2012 09:09 AM
the_donace
Oct 23, 2010 02:46 AM
baurwin
Jun 2, 2009 03:24 PM
maroman209
Dec 7, 2007 02:49 PM
