Service Engine Soon??
Old Mar 6, 2012 | 08:38 PM
Triangle12's Avatar
Default Service Engine Soon??
The camaro I just bought didn't come with a manual and on my way home tonight, the 'Service Engine Soon' light came on. Is this the same as a Check Engine Light where I have to get the code read? Or do I just need an oil change? My old acura, has a Service Engine and Check Engine light so I didn't know if the camaro was set up the same way.
fyi- the oil is pretty dark so i'm sure its due to be changed.
Old Mar 6, 2012 | 10:41 PM
You did not mention the model year, but in any case you have to pull the trouble code/s. Up to 93 the codes can be flashed, pulle with a code reader, or read with a scanner. On 94 and 95 a OBDI scanner is needed, 95s may need an OBDI scanner with an OBDII scanner cable. On 96 and newer only an OBDII scanner, or a PC with scannning software will work. Codes cannot be flashed on 94 and newer cars, and a plain code reader won't work.
Old Mar 7, 2012 | 06:29 PM
Triangle12's Avatar
Default SES light
Thanks! I had Autozone scan it and turns out its an O2 sensor. I wanted to replace it myself but they couldn't tell me which sesnor it was. Paperwork says 'heated oxygen sensor bank2 sensor 1'. I only want to replace the bad one since its $67 each. Any way to tell which sensor it is without paying a shop $100 diagnostics fee??
Old Mar 7, 2012 | 06:39 PM
bank 2 is the passenger side sensor or number 2 cylinder side. sensor 1 is the before cat or first sensor
Old Mar 7, 2012 | 07:09 PM
torque_is_good's Avatar
son, you need to discover RockAuto Auto Parts
Old Mar 7, 2012 | 07:48 PM
Triangle12's Avatar
Default o2 sensor
Thanks guys!! So, it sounds like I need the right upstream sensor and I can't believe the price difference through RockAuto parts. Is it ok to drive the car until the part comes in?
Old Mar 7, 2012 | 08:29 PM
dont use bosch 02s in a lt1, not sure how they work ih the ls1 or the 3.8 as far as that goes
Old Mar 7, 2012 | 08:48 PM
Triangle12's Avatar
Default o2 sensor
I was looking at the APWI. are they good for the LS1?
Old Mar 7, 2012 | 09:01 PM
i use ac delco. never heard of apwi might try and google apwi ls1 or something like that. may get some info
Old Mar 8, 2012 | 09:09 AM
print out the page from rock auto and bring it to adv auto, they will price match or come darn close. If they can't, then buy from rock
QuasarZ28
Dec 12, 2007 07:42 PM
bonedeth631
Nov 7, 2007 07:02 AM
chrshadil
Apr 10, 2007 09:51 PM
nike_soccer
Jan 18, 2006 12:46 PM
